administrator
USA
104 Posts |
Posted - 10/11/2005 : 23:30:10
Hey Cass!
An animation scheme is an animation that you can apply to an object in PowerPoint. For example, a text box, an image object, or a graph.
An animation scheme allows you to add movement to your slides, so for example, during your slideshow presentation, instead of the text just appearing on the screen regularly, you can apply an animation to your text which will create a special effect and make your text, or other object appear on the screen in some sort of action, such as flying, spinning, or through a zoom, or wipe etc.,
I know the first times with PowerPoint can be a bit daunting Cass, so I'll go easy on you
- Select the object or text that you wish to apply an animation to.
- View the Animation Schemes by selecting Animation Schemes from the Slide Show main menu option.
- the Animation Schemes panel, containing all of the animations you can use will appear in the “Slide Design” panel on the right of your screen.
- Choose a Preset Animation from the list.
And that's it Cass. You'll have added an animation scheme to an object in your presentation.
Admin, 123PPT.com Here to help whenever you need me.
