administrator
USA
104 Posts |
Posted - 26/04/2007 : 19:34:22
Hi Joanne,
jepp...can understand your frustration here.
Basically PowerPoint 2007 now saves its files in a new format called PPTX, or .pptx
Only Office PowerPoint 2007 can read this format. PowerPoint 2003, 2002, 2000, etc., used a format called PPT, or .ppt.
So if you have sent a presentation made in PowerPoint 2007 to someone who does not also have PowerPoint 2007 there's no way they can open it unless you resave the presentation as the older file type of .ppt under the Save As options.
Good luck with your presentation Joanne, and let us know if you are still having problems opening the presentation on other machines that are running PowerPoint 2007.
Admin, 123PPT.com Here to help whenever you need me.
